Ok folks ....what shall it be ?
Anrasp
SONY KV32FQ70 :
WEGA screen
100Hz digital plus
Vertical picture stabiliser
DNR
Auto noise reduction
Dual drive speakers
Virtual Dolby
BBE
2 x 10W plus 15W RMS output
Picture in picture
250 page teletext
NexTView level 2
Smartlink
3 scart sockets
2 RGB inputs
or
Toshiba 32ZD36P
100 Hz / DFS
Micro Filter Real Flat
PIXEL PROcessing
Progressive Scan
Digitaler Kammfilter
DNR Digital Perfect Motion
Colour Detail Enhancer - CDE
Colour Transient Improvement - CTI
Super Real Transient
Premium Scan Control Perfect Contrast
3 x Scart (1x RGB, 2x S-VHS, 3x AV)
Front S-VHS
Front-AV/Cinch
Component Video In
Any advice please ?
fatbob
Your best bet is to find a decent dealer who will let you audition the two sets with a decent source connected, such as a dvd player connected through RGB, and then decide which tv appeals to you the most.
Some people will tell you to buy the Sony and to avoid the Toshiba like the plague, while others will tell you the exact opposite. If you buy based on recommendations, you could end up with a set that satisfies another persons taste, but not yours.
Both are decent tv's, although they are not without their faults, as a quick search of this forum will show.
If I had to choose between the two sets you mention, I would probably be tempted by the superior connectivity of the Toshiba, as it allows for connection of a progressive scan dvd player via component, while with the Sony you're limited to 100hz processing, but I wouldn't make a final choice until I had seen them both properly set up.
Cheers.
Anrasp
thanks fatbob ...unfortunately here in Malta we don't have such a priviledge ...meaning that we have separate dealers so there is no way I can see the sets side by side. This is why I asked advice for expert advice here.
P
Plugman
Well I have the 28fq70 and can see little wrong now that the smear fix is fixed. Its good on football but can blur on very fast moving text. Clarity is IMHO better than a 24" Sony that I had had for 18 months. Picture is also better after some service code tweaking. The sound, so often a let down on Sonys, is very good as well. Can't comment on the Tosh but for starters you cannot adjust the tilt, which to me is a big no no. The Sony does buzz but mine is very quiet after its been of for ten mins or so.
