Ok cabling time help plz :)
Discussion in 'Cables & Switches' started by biccus1, Mar 16, 2006.
  1. biccus1
    biccus1
    Aug 23, 2002
    1,522
    Great yarmouth
    +37
    Hi all
    Ok its getting near time to sort my lounge for the new tv and i am now looking into cables :)
    This is what i will have!
    Panasonic px60 plasma (soon :) )
    TOSHIBA RD-XS345R HDD DVD RECORDER
    yamaha 757 amp (soon :) )
    skybox
    games machine x box 360!!
    laptop
    Then its looking like some monitor audio bronze speakers with a rel sub!
    Can anyone help with which cables i should buy, inc which speaker cable will be for speakers etc as i suppose i need larger dia cable for the front than the rear speakers?
    I will be using the amp as a hub for the video as well as sound :)
    I would also like sound to the plasma so i can watch sky and dvd without the amp and full speakers if need be :)
    shane
  2. biccus1
    biccus1
    Aug 23, 2002
    1,522
    Great yarmouth
    +37
    I have been looking at speaker cable and is qed micro ok for a set or MA b1s for the rear?
    And also is it small enough to lay flat under a laminate floor if i say remove a slice of the underlay (just the normal thin stuff on a roll not the thick board stuf) and not be able to know they are there?
    shane
  3. biccus1
    biccus1
    Aug 23, 2002
    1,522
    Great yarmouth
    +37
    Just found this QED Qontour Ultra-Flat speaker cable has anyone used it for rears as its only 1mm high!!
    shane
  4. biccus1
    biccus1
    Aug 23, 2002
    1,522
    Great yarmouth
    +37
    Anyone help with all the cables i should need such as which scart to s-video and which componant video what else i will need ?
  5. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    You need to give people an idea of the following before anyone will be able to help:
    • What type of signals your pieces of equipment output - RGB, component, s-video, etc.
    • How many sockets there are.
    • What type of sockets there are.
  6. biccus1
    biccus1
    Aug 23, 2002
    1,522
    Great yarmouth
    +37
    Ok i have been doing some looking and this is what i think ?
    Speakers
    qed xt 300 with airock plugs for two front speakers
    qed micro silver for centre front
    qed micro for rears
    leads
    qed pcv1 component 1m for dvd to amp
    qed pcv1 component 3m for amp to screen
    qed p75 Coaxial 1m for dvd to amp
    qed qunex 2 phono to phono 1m dvd to amp for two channel
    ixos xhw406 sub cable 3m amp to sub box
    I still need a cable to connect my sky box to the amp anyone any ideas i did think scart to s-video but not sure if the yam 757 will transfer s-vid to component anyone know?
    Coments plz :)
    Thanks shane
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    if you have Sky+ use S-video other wise you can route sky Via DVDR to get live pause etc and video conversion.
    You seem to have alot of QED cables, any particlar reason?
  8. biccus1
    biccus1
    Aug 23, 2002
    1,522
    Great yarmouth
    +37
    I only have normal sky box nothing flash so don't want to spend too much on that cable if poss.
    So if i plug from sky to dvdr box with a scart lead will i always have to have the dvdr on to watch sky?
    I just thought the qed stuff looked good for the money?
    And thing i should change?
    I also went for a demo today of the MA bronze with a rel quake sub and the yam 757 and all the leads used were qed and i liked the sound so thought i would go for them????
    shane
  9. biccus1
    biccus1
    Aug 23, 2002
    1,522
    Great yarmouth
    +37
    I am thinking of getting the denon 1920 also for this with a hdmi lead to goto my screen anyone with any ideas on a 3m hdmi?
    Also anyone else with any thoughts so far with the leads?
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    2 things why HDMI??????
    and for sky to DVD-R no not always on as long as DVD-R does RGB passthrough in standby and is connect via RGB scart to display (QED is not a way of saving on cabling)
  11. biccus1
    biccus1
    Aug 23, 2002
    1,522
    Great yarmouth
    +37
    Any reason why not Hdmi is this not the best for the player??
    So would i just need a rgb scart for the sky to the dvd-r and then the dvd-r will be connected to the amp with a component video lead then a component video to the screen or will this have to be different to this?
    The cable is part of a package which has been put together for me so can't change it too much now but is it good cabling?
    Thanks shane
  12. diegowhite
    diegowhite
    Mar 27, 2006
    13
    component is just as good as a hdmi cable in quality, and hdmi has copyrighting so it makes it harder for recording.
