OK 2 Possibly Stupid Questions
Discussion in 'Plasma TVs Forum' started by atacam, Aug 10, 2004.
  1. atacam
    atacam
    Jul 19, 2004
    452
    Southned on Sea
    +9
    I have looked in the manual for my Panasonic PWD6, for 2 things.
    1 Can I leave it on standby, instead of having to switch it off all the time.
    2 The picture keeps automatically adjusting itself. I am watching it through cable and put it to 'just', but when the adverts come on it switches itself to 16.9. It is quiter annoying.
    Please help.
  2. wattsj
    wattsj
    I too would like to know if it's OK to leave my plasma on standby all day or should I power it off\on everytime I wish to watch it. :confused:
  3. Doctorb
    Doctorb
    Jan 31, 2003
    154
    1, I personally think its better to use the power switch if not being used, ok, standby is alright if your going to switch it back on after a while but for long periods its safer as well. I remember a crt i went out to which had caught fire, set was in standby and remote was stuck down the sofa emitting the on/off signal constantly.Not sure how much power it uses in standby compared to a crt though. Better safe than sorry.
    2, Seems normal to switch to 16:9 on the just setting, why would you want to watch a 16:9 source in just mode anyway? it should return to just mode after the commercials, well it does on mine.
    Auto mode seems to switch from just to zoom if there is a dark picture which can be annoying, anyone?
  4. admerial
    admerial
    i would advise turning your plasma off. it is fine to leave it in standby for a little bit, but for long periods of time (4-5 hours) it is best to turn it off. You do not want your plama overheating. it is always better to be safe than sorry. you can also call the manufacture of your plasma and ask them what to do.
    regards, admerial
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Since it says in the manual that power consumption in standby is about 4 watts, I don't think overheating is much of a risk.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    Most displays are designed to be left in standby nowadays, not switched off all thge time, fire service tend to argue tho.
  7. Nippy_Kangaroo
    Nippy_Kangaroo
    I suppose its only the same as leaving a video recorder in standby, I dont know anyone who turns their video off.
  8. loadsofleads
    loadsofleads
    Aren't there 2 types of standby ?
    Passive and active if I'm not mistaken, passive is fine to be left on all the time while it is better to switch active standby off every night, might be wrong though :confused:
  9. Dr Downey
    Dr Downey
    Jan 12, 2004
    122
    19
    Cheltenham
    My brother in law is coming to stay at the weekend, and he won't be sleeping soundly! He's been a fire fighter for a long time, and at his house everything except the fridge gets unplugged when it's not used.
    When he sees my TV, DVD, VCR, XBOX, PS2, PC's x 2, AV Amp left plugged in all the time he'll have nightmares! :D
    I've never ever subscribed to the unplug theory, so far, so good! ;)
  10. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    So he can put you out after the flaming then!
  11. Dr Downey
    Dr Downey
    Jan 12, 2004
    122
    19
    Cheltenham
    Knew I could rely on you MAW! :D
