Oil filled heater with timer.
Discussion in 'General Chat' started by sep8001, Feb 16, 2014.
  1. sep8001
    sep8001
    May 2, 2008
    2,682
    103
    +285
    Need to get an oil filled heater with timer, any suggestion for one under £80 to heat an area approx 30m2.
    Thank you
  2. John
    John
    Dec 13, 2002
    11,635
    +3,304
    That's a big area to heat. A quick look at some of the 2kwh versions state up to 20m².
    I used to have a Challenge one from Argos to effectively and expensively heat a kitchen
  3. Peridot
    Peridot
    Aug 24, 2004
    2,995
    Newport, South Wales
    +293
    What temperature do you want to heat the room to?
    Unless it's for frost protection, you're not going to warm an area that size with a single heater.
    Whatever you choose, you may well find that a very basic heater with a plug-in time switch is cheaper and more reliable than one with a built-in timer.
  4. sep8001
    sep8001
    May 2, 2008
    2,682
    103
    +285
    Thanks. The room will have underfloor heating as the main source, but am thinking of getting one to use as and when needed also need one now to get the plaster to dry.
  5. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,187
    +7,324
  6. sep8001
    sep8001
    May 2, 2008
    2,682
    103
    +285
    Thank you,did see that when I searched, but still not sure if I should go for a better quality one like dimplex with the 3 year warranty or delonghi with the 10 year warranty?
  7. Epicurus
    Epicurus
    Jan 17, 2006
    3,706
    +696
    Surely better off with a fan heater in a room of that size, dimplex make nice stove heaters.
  8. sep8001
    sep8001
    May 2, 2008
    2,682
    103
    +285
    Picked up a 4 month old delonghi dragon 4, will test it tomorrow..
    Thanks for all the help and suggestions.
