Ohms
Discussion in 'Home Cinema Speakers' started by arn, Feb 3, 2005.
  1. arn
    arn
    Dec 26, 2003
    270
    Bury
    First of all, don't know if this should come under amps or speakers but i will guess here.
    Been reading my manual and it says i should only buy speakers that match the recommened ohms (something like that anyway) for my amp.
    anyone have a link or a guide to what this and other av tech meens in my language :)
    also is it best to go above or lower of the recommended?
    Noob question i know, but hey i am a noob and proud :smashin:
    and also ( i know again ) what is immpedence?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Here are a few threads on the topic that I found using the search function
    (keywords: Ohm, impedance):
    http://www.avforums.com/forums/showthread.php?t=184124&highlight=ohm+impedance
    http://www.avforums.com/forums/showthread.php?t=180121&highlight=ohm+impedance
    http://www.avforums.com/forums/showthread.php?t=156959&highlight=ohm+impedance
    http://www.avforums.com/forums/showthread.php?t=157905&highlight=ohm+impedance
    Generally above, i.e. chose 8 Ohm over 4 Ohm.
    AC (alternate current) resistance. Impedance is not a constant, it varies with frequency.
    DC (direct current) resistance in comparision is a constant.
