Ohms Parallel and series?
Discussion in 'Home Cinema Speakers' started by Andy Dee, Apr 25, 2005.
  1. Andy Dee
    Andy Dee
    Sep 1, 2002
    205
    +3
    I am really unfamiliar with mixing series and parallel wiring, but i am sure someone will know how to do, what i am trying to do.
    I have three paris of 6ohm speakers that i want to run from a dual channel Power amp (three off of each channel)
    I do not want to go below 4 ohms, and ideally like to stay at 6ohms.
    Can someone draw me a little diagram showing me how it can be done?
    Andy
  2. nheather
    nheather
    Oct 6, 2004
    17,440
    167
    Horsham, West Sussex
    +6,796
    Speaking from just an electronics point of view
    all three in series = 18 ohm
    all three in parallel = 2 ohm
    two in series and one in parallel = 4 ohm (but uneven loading)
    two in parallel and one in series = 9 ohm (but uneven loading)
    Can't think of any other combinations.
    Cheers,
    Nigel
  3. Andy Dee
    Andy Dee
    Sep 1, 2002
    205
    +3
    Hmm,
    Buying a fourth pair of speakers evens out the load then?
  4. nheather
    nheather
    Oct 6, 2004
    17,440
    167
    +6,796
    With four you could do
    (2 in series) in parallel with (2 in series) = 6 ohm
    So the load will be even, but remember that each speaker will get 1/4 of the delivered power.
    So if your amp supplies 50W ...
    For a single speaker ... it will deliver 50W
    For 4 speakers ... each will deliver 12.5W
    Cheers,
    Nigel
  5. Andy Dee
    Andy Dee
    Sep 1, 2002
    205
    +3
    Cheers,
    I have done a quick sketch as to how i think i need to wire it for 6 Ohms. Does this look right?
    Wiring
    Andy
  6. nheather
    nheather
    Oct 6, 2004
    17,440
    167
    +6,796
    Yep, that's what I meant - bear in mind this is from a purely electronics point of view - I couldn't comment on what it would sound like.
    Cheers,
    Nigel
  7. Andy Dee
    Andy Dee
    Sep 1, 2002
    205
    +3
    Thanks Nigel,
  8. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
