Ohms on pioneer????
Discussion in 'AV Receivers & Amplifiers' started by durk, Jul 2, 2003.
Tags:
  1. durk
    durk
    Wot r you supposed to do if your center and rear speakers are 8 ohms and your fronts are 6 ohms??#
    or any mix of differnt speakers???
    (prob set it all to six i guess) :eek:
  2. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    Yes set to 6 if any speakers are below 8ohms.
    To your other questions...it's up to you if you bi-amp the fronts or not...try either confirguration and see what sounds best, and yes run the set-up again if you change to bi-amping.
  3. nathan_silly
    nathan_silly
    When you biamp, make sure you remove the speaker bridging links (on the speaker terminals) otherwise the amp will go pop.
  4. durk
    durk
    with regards to the link
