Ohms - Matching Amps & Speakers
Discussion in 'Home Cinema Speakers' started by Lesmond, Apr 7, 2003.
  1. Lesmond
    Lesmond
    Jan 29, 2003
    +3
    The amp and speakers I'm going for are slightly miss-matched with regards to ohm ratings...
    The Harman Kardon amp output is rated at 8 ohms impedance, but the speakers are rated at 6 ohms.
    Will this affect anything in terms of performance? Will I need to be cautious in any way when using the setup in this configuration?
    Thanks for any help!
    Les.
  2. nathan_silly
    nathan_silly
    Nah. Only worth bothering about if your speakers are 4 Ohm.
    Has your amp got a switch at the back for impedance setting? Follow the manual instructions. Flick the switch (if there is one) with the amp switched off and the plug removed.
  3. Lesmond
    Lesmond
    Jan 29, 2003
    +3
    Thanks Nathan - I can't see a switch, but if it's not a problem either way, I'm happy with that!
    Les.
  4. nathan_silly
    nathan_silly
    btw what model amp is it? And the 5 speakers?
  5. EvilMudge
    EvilMudge
    Not surprised, HKs are some of the few AV amps that can drive 4Ohm speakers without problems.:smashin:
  6. Lesmond
    Lesmond
    Jan 29, 2003
    +3
    The setup (will be, when it arrives)
    HK 5550 receiver with Monitor Audio Silver speakers (S2's, S1's and SLCR + Velodyne CHT-10) & QED Silver Anniversary.
