MaryWhitehouse
I’ll try and explain this clearly but apologies if not. I can get more pics or a diagram later.
My Mrs has ordered a Mokka-e as her next Motability car, which will arrive one day! As part of the lease Motability contract Ohme to install a charge point, who in turn sub-contract AES-Charge to install.
What I’m trying to determine from you learned folks is if the install is actually different at our home or just a slight change. AES-Charge have said it’s non standard with an extra charge but won’t discuss with us. Motability are trying to sort it out.
We live in a rural rented property (with permission for the install) which was a farm. If you imagine coming up the drive, at the top the meter shed (farmyard still has a three phase install) is about 10m to the left and our house is about 10m to the right. Obviously, at least I think so, there is a cable between the meter and the consumer unit which is in a kitchen cupboard at the nearest corner of the house. The charge point needs installing on one of the walls on the outside of this same corner.
AES-charge seem to think (but won’t discuss with us) that they need to charge for a connection at the meter end and cable and trench to the house.
My question is do they need to do this? Can’t the charge point connection be at the house end of the cable between meter and house, not the meter end. This would obviously negate the need for the extra work.
Thanks all.
Thanks all.
