Oh No Help!!!!!!!!!
Discussion in 'Plasma TVs Forum' started by nashb, Dec 18, 2004.
  1. nashb
    nashb
    Dec 15, 2004
    270
    16
    Nottingham
    Hello clever people Im stuck!
    Im sure this sounds stupid but Ive done a search and cant find an answer.
    Just setup Panny 7 with JS with BNC componenent and Sky dig but the picture looks green, ie cant get any reds. Have switched connections and played with setup on Panny including reset to factory but no joy.
    Help its only six days to Xmas!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    JS what JS RGB>VGA or JS RGB>YUV and have you selected the correct either RGB (HV) or YUV(component) in panny input settings? This is usuallly the problem that or on eend of cable isnt connecting properly....
  3. nashb
    nashb
    Dec 15, 2004
    270
    16
    Nottingham
    Boy u r quick HD! RGB to YUV and chose component in Panny menu.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    in that case double check all leads (dont forget the Scart lead) are connected properly, also that component board is seated (try swapping red and green component lead around) and that source is set to RGB
  5. nashb
    nashb
    Dec 15, 2004
    270
    16
    Nottingham
    Loose cable for the red signal! Thanks HD u r the best.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
