Oh my, PLEASE tell me this will work with xbox 360!
Discussion in 'LCD & LED LCD TVs Forum' started by clubber, Nov 8, 2005.
Tags:
  1. clubber
    clubber
    TV
    Ok the link above is a TV i found on Dabs.com
    It says it 'supports' HD. Please tell me i can play my xbox 360 in HD on this baby? Its just TOO cheap to be true!
    If it does play with the 360 i'll cancel my Sasung 32" HDTV and order this peice of kit strait away!
    Please reply asap as my Samsung is being procesed.
    Thank you
  2. bignige
    bignige
    May 13, 2003
    718
    +32
    The resolution won't give you true 720p or 1080i
  3. Eiji
    Eiji
    Feb 16, 2005
    1,423
    48
    +70
  4. clubber
    clubber
    So it wont play the 360 in HD?
  5. Raze
    Raze
    Dec 21, 2003
    875
    UK
    +13
    NEVER buy a 'cheap make' plasma or LCD - it will be total crap!!!
    trust me on that one :p
  6. Eiji
    Eiji
    Feb 16, 2005
    1,423
    48
    +70
    No.
  7. sparkymark75
    sparkymark75
    Jan 6, 2003
    3,239
    Fife
    +747
    If it seems to good to be true, it usually is!
    For that price, get the Samsung LE32R41(51)B which is HD.
  8. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Agreed. A good quality plasma is going to cost three times that. Also the plasma in the link doesn't seem to have component inputs either which is what the 360 needs. I would advise against getting that TV.
  9. Northerner76
    Northerner76
    Sep 11, 2005
    926
    28
    Wells, Somerset
    +26
    Just to echo what everyone has said... I wouldn't touch that TV with a barge pole, especially if you are looking to exploit High Definition images.
    If your budget is approx £800-900 you would be better off getting a good quality 32inch LCD, something like the Samsung already mentioned... or perhaps the Toshiba 32WL56 (although that would need an additional component to DSUB connector to accept the Xbox 360 High Definition video output from the component cables)
    Basically to be pretty sure you are buying a High Definition screen you shoudl look for a "HD Ready" logo, this is NOT the same a HDTV compatible or EDTV - the screen shoudl also have a minimum resolution of 1280 x 720 (although most HD Ready screens will quote the W-XGA standard resolution of 1366 x 768)
    Also, that DabsValue TV is a Plasma... I would imagine budget plasma would still suffer from screen burn/image retention... whereas a budget LCD will not.
    Final point for Xbox gaming to be less suscpetible to blur or smearing pick a screen with a good fast response time (anything sub 16ms should be OK - in most cases)
  10. clubber
    clubber
    Thanks alot. appreciate the comments :)
  11. po_man
    po_man
    Dec 23, 2004
    1,712
    St Albans
    +63
    Mission Accomplished ... Next ...!
  12. bonc
    bonc
    Some would consider the Samsung a cheap make LCD! :D
  13. Digitised
    Digitised
    Oct 11, 2004
    177
    +13
    lol that wont even display PAL properly let alone 720p
