Oh Dear Pixel Help
Discussion in 'Projectors, Screens & Video Processors' started by rizla, Nov 25, 2003.
  1. rizla
    rizla
    13 hours on the lamp and I was just checking up close to the screen when I noticed what MAY be dead pixels. There is one pixel near the centre bright but I dont think at full brightness GREEN in colour. There is ALSO ABOUT 5 TO 6 BLUE ONES ,
    They are only seen during a black screen background as when its blue the pixels change to blue and disapear.
    I had a DPC before purchase so was wondering do I return it to the supplier or should I forget them as I cant see them when watching a film.
    Thanks Guys
  2. clancol
    clancol
    Sep 6, 2003
    988
    Middlesbrough
    +6
    if u can't see them now, you will soon because your eyes will hunt for them.
    its impossible 2 forget about them. and a dead pixel check is sopposed to check for dead pixels. return it
    if u want!
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,815
    Somewhere in South Yorkshire
    +5,023
    I would guess that 7 bad (bright) pixels is outside of the manufacturer's tolerance and you are due for a replacement.
