Official Wii RGB Lead - Dark Image
Discussion in 'Nintendo Wii-U & 3DS' started by Stevesurround, Mar 9, 2013.
  1. Stevesurround
    Stevesurround
    Nov 11, 2008
    15
    Hi all
    I'm hoping someone can help.
    I recently picked up an official Nintendo Wii RGB lead from my local Blockbuster video stores closing down sale.
    When I got it home and hooked it up it initially gave me a green image so I checked the connections and turned everything off and on again and now the colour is correct but the image is noticeably darker than the image I get using the standard composite av lead.
    Is this normal for RGB scart?
    I'm using it with a Sony KV-20WS1U tv. This has one Scart input but I believe it is RGB compatible.
    Hopefully someone can help!
    Thanks.
  2. safcalibur
    safcalibur
    Nov 23, 2008
    7,762
    Cambridge
    +4,253
    Other than making sure the connections are correct and the leads pushed all the way in I think you may need to adjust the brightness on your TV. Best lead in the official nintendo COMPONENT lead, that will give you 480p video output. RGB/SCART/COMPOSITE are all lower quality and hit and miss.
    Saf
