Offical Sony PS3 bluray remote
Discussion in 'Playstation Forums' started by gers1978, Jun 1, 2008.
  1. gers1978
    gers1978
    Aug 2, 2006
    1,581
    Glasgow
    +173
    Any idea why the remote gets assigned controller number "7", and the lights for 3 & 4 show up when the PS3 button is pressed to check which controllers are connected?
    Why not just give it the next available number like a normal sixaxis?
  2. tigandken
    tigandken
    Jun 27, 2007
    288
    +21
    So it doesn't conflict/confuse if you then connect other pads to play.
  3. Gadgetcity
    Gadgetcity
    Apr 2, 2008
    850
    43
    Christchurch, NZ
    +149
    As Tigandken says, so that the remote doesn't get controller "one" if the PS3 is turned on with it. I have an infra red remote as well that plugs into the USB. If it is plugged in at power up it assumes controller "1" and you have no controller in games from the sixaxis so you have to re-assign it every time you start the PS3. Sony obviously came across this with their Bluray remote and have catered for it by using controller "7" for the bluray remote.
    I had wondered about that until I got an infra red adapter so that I could use my AV remote for movie watching in the dark (lights up the buttons)
