Off to Hong Kong and China should I buy a laptop
Discussion in 'Desktop & Laptop Computers Forum' started by gadgetman, Feb 4, 2009.
  1. gadgetman
    gadgetman
    Sep 22, 2002
    462
    Bridgnorth
    +12
    I`m off to China in March and will be staying for a couple of days in Hong Kong. I have been looking for a new laptop but only loking to spend about £400. Looking for decent spec with perhaps blu ray, hdmi out, 3 gig ram, etc. Will it be much cheaper from either HK or China. Would buy from respectable store with hopefully international warranty.
    Any ideas?
  2. Sleeco
    Sleeco
    Oct 29, 2007
    49
    +5
    Hi, I've just been t HK and found things to be more expensive than here for a quality laptop, i don't know about China.
    Get some prices here and compare.
  3. Richie_UK
    Richie_UK
    Nov 14, 2006
    102
    28
    +33
    The current weak value of the £ will probably make buying abroad poor value. Even when the £ was strong a few years ago when I was out in Japan the prices were not signiicantly cheaper, but you vould get newer models which were not on sale here yet in the UK.
  4. cattythefatty
    cattythefatty
    Nov 13, 2008
    34
    hi pal
    the £ is low very low in January £1 = HK$10.30 that is the worst I have got from there in the last 7/8 years I have been going there
    and AVOID the doggy shop’s on & around Nathan Road
    they offer gold at the price of silver
    once they have your cash they even on credit cards they will say they other shop or suppliers is out of stock
    Then they till take you in to buying gold at the price of Diamonds
    Stick to the chain shops but the £ is way down I think you will be better of buying in the UK
    And have a look at the link below about the scams that go on their
    Any way have a good trip
    Hong Con: Avoid the scams and rip-offs | Batgung
