Quantcast
Off the shelf PC recommendations.
Surebrec
ok, this is not a PC for me, this is one for my dad, and I don't know why, but he has some fixation with buying off the shelf, either at PC World, dixons, currys etc. I explained to him the downsides of purchasing from companies like this (vague component details, no installation cd etc), but it doesn't seem to sink in with him.
he said his budget is about £600.
he's after a general usage pc with a bit of room to stretch its legs in terms of power. he's not a gamer, so graphics is not really an area it needs to excel in, though to stop his nagging later down the line, I would like something that can handle some older games, albeit on medium-low settings.
I've had a look, but you know what these off the shelf companies are like, they just show the HDD capacity, RAM etc without going into detail.
I've had a look on currys, and going from past experience (this is about the 6th time he has asked me to look for a computer for him, only to then find some excuse not to buy (he's a bit of a skinflint and won't spend if he can help it)) I know they all sell the same models really.
anyway, after checking the models, I have found this:
ADVENT Advent DT1410 Desktop PC Bundle with Samsung S22A100N 21.5" Full HD LED Backlit Monitor buy online | Currys
what sort of performance can be expected from a pc with these specs? what would be a better investment?
bear in mind that as I said, its going to be a general usage pc, with a bit of room to stretch in future. I don't want to point him in the direction of something that is going to be crawling like an old man with one lung within a year
betelgeus
i can only talk about my own experience and i see 3 problems,it's an advent,has onboard gpu and has no pciex16 slot.
too answer them,advent are a horrible pc world own brand that spend nothing on cooling or peripherals,the on board gpu is very low,lower than my old 8400gt from 4 years ago and that could do nothing and the 3rd problem is you cant buy a new gpu as the motherboard has no slot.
i'll look around and post back later.
LJx
The monitor with that PC is only £80 so don't let that make you think it is better deal than it is. I think one of the i3 systems you seem to be able to get from places like that would be better value at about "£300 and would be plenty powerful
betelgeus
i agree,the 6gb ram and i5 proccessor seem overkill for what your dad needs it for and the bottlekneck of the gpu.even ask him if 1.5tb seems reasonable for his needs.
maybe an i3 system with 4gb ram and a good ssd with a 1tb backup drive and better gpu would suit him better
bryanchicken
Well, hardware doesn't get slower with age. So as long as he is doing the same things with the same software then it will be the same performance.
If performance has degraded then reinstall Windows. Voila.
Surebrec
I decided to have a look at the site where I got my pc, and did a quick spec keeping his budget in mind, this is what I came up with.
Case
STYLISH PIANO BLACK ENIGMA CASE + 2 FRONT USB
Processor (CPU)
AMD A8-3870K APU (3.0GHz, 4 Cores) & AMD Radeon™ HD 6550D Graphics
Motherboard
ASUS® F1A75-M: FM1 A-SERIES, SATA 6.0GB/s, USB 3.0
Memory (RAM)
4GB SAMSUNG DUAL-DDR3 1333MHz (2 X 2GB)
Graphics Card
Integrated AMD Radeon HD 6000 Series Graphics
Memory - 1st Hard Disk
1TB WD CAVIAR GREEN WD10EARX, SATA 6 Gb/s, 64MB CACHE
1st DVD/BLU-RAY Drive
24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Memory Card Reader
INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply
350W Dual Rail PSU + 120mm Case Fan
Processor Cooling
STANDARD AMD CPU COOLER
Sound Card
ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities
10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
how does this compare to the off the shelf models?
Similar threads
