Off-centre projectors...
Discussion in 'Projectors, Screens & Video Processors' started by j05ha, Nov 15, 2003.
  1. j05ha
    j05ha
    Hi all,
    I'm new to this so go easy on me, I've searched the forums already but can't find what I'm looking for.
    Can anyone reccomend a projector cablable of being mounted off-centre? I'm aware of Sony's Side Shot(TM) technology but does anyone else offer a similar thing?
    Btw - cost is an issue so sub £1500 would be ideal and is to be used primarily for data projection.
    Any help is very much appreciated!
    Cheers,
    J.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,011
    +2,808
    Immersive Virtuoso does this extremely well. Except it's about 5 times your budget.....
  3. j05ha
    j05ha
    Thanks, but as you say it is a touch over budget! Nice piece of kit though....
    Surely this functionality is available at the lower end from someone?
    Cheers,
    j
    PS - pls excuse my spelling!
  4. silent lucidity
    silent lucidity
    How about the lens shift feature on the Sanyo PLV-Z1 and the imminent PLV-Z2?
  5. MRW
    MRW
    Aug 8, 2002
    238
    High Wycombe, Bucks
    +3
  6. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,915
    38
    UK
    +7
    How does Lens Shift differ from keystone correction? I understand that to position a PJ to the side as you can with the Sony, you need horizontal keystone correction.
  7. j05ha
    j05ha
    From looking at all these it seems the 'lens shift' feature is basically a form of horizontal keystone.
    The NEC can be placed at 30deg to the screen although I think this would depend how far away it is. I'm not sure how this compares to the Sanyo or Sony (if you believe the sony brochure it looks as though it can placed at >45deg!!)
    Has anyone used either the Sanyo or the NEC?
    Again, many thanks for all your help!
    J.
  8. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    This might seem like a strange reply, but...
    If you are mostly displaying computer presentations why not try rotating your data by 90 degrees and sitting the projector on its side. You could then use the keystone adjustment to correct the shape.
    Note. keystone adjustment (both horizontal and vertical ) will gratly reduce the displayed resolution of the projector.
    I would always try to get directly in front of the screen and use no keystone at all if possible.
  9. yatesd2404
    yatesd2404
    The Sharp XV-90/91E does both horizontal and vertical keystone correction and would come in around your budget (last time I looked anyway).
    Not sure what the max., off centre position allowed/capable is, but I do have the electronic user guide that covers this if you are interested.
    Cheers,
    Dave.
  10. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    the sanyo lens shift is supoosedly unique from keystoning in that it shouldnt be introducing distortions like keystoning will
    ad
  11. JUS
    JUS
    Jan 21, 2003
    3,200
    Plute
    +241
    I've got a Sanyo Z1. I don't have it in a fixed position. So I just plonk it down and turn it on. It's never usually dead center.
    Lenshift allows me to position the projector to the left/right of center. All it is is a little manual wheel that turns the lens to point in a different direction. I've never really noticed any distortion and never heard of anyone reporting any but I guess the picture can't be spot on if you're using it.
    Keystone correction on the Sanyo allows you to position the pj lower than the bottom of the picture. If the lens is pointing upwards you would naturally get a rombus shaped picture \____/. The Keystone allows you to electronically adjust the picture to make it straight |____|....just like you had the pj at dead centre.
    Z1 is now about 900 quid I think. Z2 out now or any day now.
  12. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Optical lens shift (Sim2, Sharp, Sanyo ) is very different from digital keystone correction which is best avoided as it does degrade the image.
  13. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    Lens shift does NOT produce perceptable distortion.
    Think about it - if it did then ALL projectors would be distorted as non lens shifted pjs are actually FIXED at FULL vertical lens shift (compared with the Z1), which would mean they had maximum distortion.
    It also has NOTHING whatsoever to do with keystoning.
    The Z2 is rumoured to have twice the limit of lens shift of the Z1. This would make it a very flexible machine with little need for keystoning at all. It has not been comfirmed yet.
  14. JUS
    JUS
    Jan 21, 2003
    3,200
    Plute
    +241
    lens shift will make the picture appear not straight..I would call that distortion.
    e.g. If you have your projector lower than the screen the picture will not be centred on the project screen. You then use lenshift to move the picture up. The screen is now on the screen but the bottom of the picture will be smaller than the top of the picture because the lens is nearer the bottom of the screen. The use of keystone fixes that. On the z1 keystone can't fix the distortion which occurs when you put the projector to the left or right of the screen.
  15. Woz!
    Woz!
    Oct 27, 2003
    107
    16
    Bracknell
    I think you're wrong on this point.
    Lens shift on the Z1/Z2 does not distort the image, it merely repositions it on a flat plane. The PJ still needs to have its lens parallel to the surface onto which it's projecting, it can just move that image around (quite a lot as I understand it).
    You seem to be suggesting that it moves the image by pointing the lens in a different direction, and this isn't how it works.
  16. Kramer
    Kramer
    Oh contrare :)
    Lens shift does move the lens so it's "pointing in a different direction" - eg. up/down or left/right.
    :smoke:
  17. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    Click here for explanation
    By the way kramer I did get out of the right side of the bed, I was joking too, except my joke was funny!
  18. The Boogerman
    The Boogerman
    Dec 22, 2001
    39
    Bavaria
    Doesn't the Pansonic ae300 do horizontal or vertical (ie not both at the same time) keystone corrention?
  19. chris l.
    chris l.
    Mar 31, 2002
    270
    +3
    For Info:
    Little video (german) of lens shift function on PLV-Z2.
    Regards,
    Chris
  20. chris l.
    chris l.
    Mar 31, 2002
    270
    +3
  21. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    So to conclude, lens shift doesnt distort the image.
  22. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,757
    Cheshire
    +108
    :eek: Generally not recommended unless the projector is specifically designed for that use.
    Regards
  23. j05ha
    j05ha
    Again, thanks for all your help! I had contemplated mounting the projector on its side but, amongst other things, it messes up your aspet ratio, and I then have the problem of mouting it dead center, erm, vertically, i think.
    So, it seems I'm down to Lens Shift or Horizontal key-stone.
    Lens Shift doesn't distort while key-stone would seem to offer more flexibility (ie I can mount further of center). The Lens Shift on the PLV-Z2 looks impressive (cheers Chris l.!)
    Looks like throw distance may also become a factor in my decision. hmmm there's more to this than meets the eye :)
    I'm going into London on Saturday (Totenham Court Road, here we come!) so I'll try a few and see which one works out. I'll post my findings!
    Thanks again.
    j
  24. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Jo5ha,
    If mounting off centre is to get a bigger image then another option is to mount the projector centre but project the image upwards and use a mirror at 45 degrees to reflect image on a wall. This might look a bit ugly but gets extra throw in a short room.
    Im not sure if all projectors can do this but the japanese brochure for the Sanyo Z2 shows this configuration.
    Here is the PDF brochure, look at page 4, labelled private room
  25. j05ha
    j05ha
    I shouldn't have a problem with the throw distance as such I was just wondering if the it may affect how far to one side I can mount the projector. The key-stone effect increases as you move the projector towards the screen you see so I ws just thinking outlound as to how this might affect my positioning. I can feel an excel spreadsheet coming on!
  26. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    Jus, you have no idea about optics, do you? :rotfl:
    Like I said before MOST projectors have a fixed vertical lens shift which allows the picture to be above the height of the lens when the pj is upright and below when ceiling mounted.
    If you were correct then the only projectors to NOT need keystone correction would be the likes of the Sanyos at zero lens shift.
    Also if you were correct, ALL projectors would have increasing distortion to the edge of the picture as the edges have a fixed effective lens shift in comparison to the centre.
    Kramer, two people, near each other, pointing in a direction parallel to each other, are generally considered to be pointing in the same direction. Ergo a lens which has moved orthogonal to it's axis a centimetre or so is still pointing in the same ordinal direction. IE if it was pointing north 000' before it will still be pointing in the same direction after lens shift.
    To make it plain, the lens shift does NOT change the ANGLE of the lens.
    Any distortion comes from stuff like the fact that a lens is not hyperbolic as it should be, but instead uses a small arc of a circle as an approximation. The further from the centre of the lens you go, the worse that approximation becomes and therefore produces distortion.
    The compound nature of the lens to ensure other distortions are reduced eg chromatic aberration, will not work so well at off axis extremes either.
    Hope this clears things up.
    ps As the lens will be designed to have unnoticeable distortion at a distance of the screen height from the center, the Zanyo Z1 can have no more noticeable distortion than any other pj. As the Z2 which goes beyond this limit, it will have to have a lens which can cope.
  27. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Oh :confused:
    I was with you up until "To make it plain...."
    :rotfl:
  28. JUS
    JUS
    Jan 21, 2003
    3,200
    Plute
    +241
    calscot,
    Ok smarty pants :rolleyes: I'm keen to try and understand what you are saying here...
    "two people, near each other, pointing in a direction parallel to each other, are generally considered to be pointing in the same direction. Ergo a lens which has moved orthogonal to it's axis a centimetre or so is still pointing in the same ordinal direction. IE if it was pointing north 000' before it will still be pointing in the same direction after lens shift."
    Starting point: my lens is pointing north 000. I now change the len shift to move the picture two feet to the left. Are you saying my lens is still pointing north 000 ?
    Jus.
    P.S. Watching the vid it looks like the Z2 works differently to the Z1. When I lens shift on the Z1 my picture's shape changes.
  29. Draco10
    Draco10
    Nov 19, 2003
    29
    Brighton Sussex
    +5
    jo5ha
    With regards projector choice,i"ve been using a Pany AE300 for a few months now and found it to be excellant for all sorts of use.The socketry on the back is more than ample for mosts needs be they Film(DVD,Laserdisc, VHS even gaming via the RGB equipt scart socket).There's also PC inputs which i use on a regular basis.The only caveats with this i find are having to increase your font sizes and not being able to view in full widescreen(only 4:3)because of picture distortion,but unles you've a dedicated widescreen video card i would assume you'll get this with any projector)correct me if i'm wrong).Computer wise i use a mac and manage to get XGA resolution.Which seems more than adequate.
    Gaming is something i've only just got into,computer games seem to pose no problems for the AE-300.Platform games seem easier to view probably because there's less movement going on,Driving games and shootem ups fair not so well(that's probably an age thing).When your 10ft away from a 7ft screen it becomes a bit intense.
    On a positive note though,you don't have to black the room out totally to get descent results.As long as you don't direct light onto the screen,i've found i have no problems(even with the lamp set to low power mode).
    If you're a true gamer,my advice is get a console(they are amazing!!!!!!!!).I borrowed a mates Sega Dreamcast and it is sooooooo much fun.Gaming on the big screen in the evening with your mates with a few bevvies can't be beaten.Saving up for the new X-BOX(as long as it's got RBG outputs you can't go wrong).
    Phew!
    With regards offcenter mounting:
    I've tried mine setup in various aspects,Ceiling table top and wall mount positions.
    Because the AE300 has both horizontal & vertical keystone correction which can be adjusted independantly,i found positioning not a problem,the short throw lens maybe though.My setup is as follows:
    Projector table mounted with lens approx 11ft from 92"diag (45"x80") screen with zero keystone adjustment and the manual zoom ring set to minimum the image fills the screen.The zoom ring could make it larger,but this is the minimal picture size for the distance used.This is fine if your wall space is able to cope with images of this size.
    You don't state how large you want to project,so this may suit you.(if in doubt,visit the Panasonic web site for spec sheets).
    I have been able to position the projector at either extremes of the room(11ft6")at this distance from the screen and(using the keystone adjustment)been able to get avery good resulting picture image.
    I know that picture degradation occurs and purists would throw up their hands in disgust,but the thing is keystone correction was invented to help you out when needed,so...if you can't get the perfect placement and you've found the projector you want...use it.If it wasn't supposed to be used,it wouldn't have been provided.
    As far as price goes(if you have'nt already) get a copy of Home Cinema Choice magazine and browse through the adverts.I managed to save a couple of hundred on the Pany by getting quotes from retailers and taking my HC Choice mag to a local Pany shop.I told them the lowest quote and they matched it,the money saved went towards an electric screen instead of a manual one.Best of all,i now have piece of mind(not buying a grey import)
    if it did go wrong i can just nip down the road and consult the dealer on my own home turf.
    With the imminent release of the PT-AE 500 you should have more bargaining power as they will want to move stock.
    Anyway goodluck with your search and i hope my ramblings have helped you out.
    http://www.avforums.com/forums/newreply.php?s=&action=newreply&threadid=102833#
  30. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    Jus,
    Maybe North was a bad example as we are on a circular plane on earth.
    So the answer is near as damn it yes. The only reason that the answer isn't 100% yes is that two parallel lines in a flat plane will not meet and therefore will not meet at the north pole. The angle would have to be slightly different for that to happen rather than the same.
    If you move the lens, the image will move the distance multplied by the factor of diffence in size between the image on the screen and the size of the image while passing through the lens.
    The picture will be projected on the same plane and so there will be no distortion with a perfect lens and no keystoning required. It will be pretty much the same as if you moved the projector to the right, but obviously by the distance moved on the screen rather than the lens movement.
    If you think about it this must be true. If you take the left hand edge of the lcd panel for instance. It is not in the centre of the axis of the lens, yet its light is projected in parallel with the centre of the lcd panel's light, giving an undistorted picture on the right hand side.
    Now supposing you move the lens so the centre is now effectively where the left hand edge was before, it will be no more distorted than the left hand edge was.
    As we have not said how far to the left the lh edge was, we can obviously extrapolate this and conclude that where-ever the left hand edge is now, it will not be distorted.
    You are basically just moving the picture right
    The limiting factor of this is obviously the size and quality of the lens as the further from the centre you go the more of a grazing angle you have from the lens and the limitations of the lens come into play. That is what limits how far you can lens shift.
    The Z2 is rumoured to lens shift by more than the Z1 and so either the lens is fine and can take it or they have changed the lens.
    It's very good news for people with high ceilings.
