OFA URC-7562 remote - problem with code downloads
Discussion in 'Home Cinema Control & Remote Controls' started by dr-manhattan, Apr 22, 2005.
  1. dr-manhattan
    dr-manhattan
    hi - this is my first post, so be gentle with me!
    I've got the OneForAll URC-7562 (B00), which I'm generally pleased with. However, when I downloaded the code for my Pioneer DVR-220 dvd recorder (code 0631), it wiped the code for my Thomson DHD-4000 hard drive recorder (code 1291). I had told the rep that I had previously downloaded the Thomson code.
    When I phoned them back and told them, the rep said "no problem" and resent the code for the Thomson. This now works, but it's wiped the code for the dvd recorder!
    Help!!
  2. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    You need to tell them to download both codes at the same time.
