OFA Mosiac - first charge
Discussion in 'Home Cinema Control & Remote Controls' started by marshy.dave, Apr 21, 2004.
  1. marshy.dave
    marshy.dave
    According to the instructions it takes about 12 to 14 hours to chard the battery for the first time using the docking station.
    I plugged mine yesterday at 6pm and at 8am this morning it still says low battery and doesn't even power the backlight. What am i doing wrong???
    I have tried normal betteries and the romote is fine with them?
    Any clues anyone
  2. sceptic
    sceptic
    Aug 13, 2002
    663
    Bridgend
    +19
    Was the charging light on?
  3. marshy.dave
    marshy.dave
    yes mate the red light at the bottom is on
  4. sceptic
    sceptic
    Aug 13, 2002
    663
    Bridgend
    +19
    When I first recharged mine it didn't appear to have worked - the "battery low" message still showed. After pressing the buttons a few times the message disappeared and the unit was, in fact, charged.
    If that's not the case I guess the unit is faulty as was my first one.
    I took it back to Richer Sounds who changed it without any problem.
  5. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    could be duff battery
    mate of mine bought one and battery duff, get it replaced
  6. robyoung
    robyoung
    Nov 9, 2003
    939
    Milton Keynes
    +65
    i was thinking of getting a OFA Mosaic. What do you think of it? Does it do everything you want it to? A
    Any bad points (apart from the charging!!)
    cheers for your help, i want it to control my LG Plasma, JVC VCR, SKY + (does it do that?), Sony Amp and Panasonic DVD player?
    Does it have Macro capability as well?
    Sorry for all the questions, i dont know much about it!
    cheers rob :D
  7. sceptic
    sceptic
    Aug 13, 2002
    663
    Bridgend
    +19
    I've got one controlling 9 devices am very pleased with it. Charging has been no problem to me.
    I haven't got Sky+ so don't know exactly how it copes with that.
    It has got the facility to learn from existing remotes and also has macro capability.
    HTH
  8. robyoung
    robyoung
    Nov 9, 2003
    939
    Milton Keynes
    +65
    Thanks for the reply.
    Do i have to have the original remote or can it replace one thats been lost (as my sony Amp remote is gone!), thats the main reason i want it, as to replace the Sony remote it will cost me nearly £200!!!
    cheers again
    Rob
  9. sceptic
    sceptic
    Aug 13, 2002
    663
    Bridgend
    +19
    I would guess it would be able to operate a Sony amp. It would certainly control the main functions like volume and input select.
    Have a look at their website:
    http://www.oneforall-int.com/index.html
    There's lots of info there.
  10. robyoung
    robyoung
    Nov 9, 2003
    939
    Milton Keynes
    +65
    Thanks again for the info and the website.
    Lots of info there, sounds like just what i need! Might have to make a trip to Richer Sounds soon!
    cheers :-D
    Rob
  11. smerkderk
    smerkderk
    Oct 15, 2004
    44
    Berko
    Robyoung,
    Just got one from the dreaded e-bay , well happy with it, the learn facility is great, all for under £40!!! only thing i would point out is the display could be brighter / clearer, this is not a major issue at all though.
