OFA Magic numbers for Pace Twin DTT
Discussion in 'Home Cinema Control & Remote Controls' started by kevenh, May 8, 2003.
  1. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Royal County Of Berks...
    Not all of them, just the easy ones!
    181 = Power Toggle
    148 = TV1-TV2 switch
    090 = Cursor left
    153 = Cursor Right
    086 = Cursor Up
    151 = Cursor Down
    150 = CH Down
    155 = CH Up
    149 = OK
    213 = 1
    217 = 2
    215 = 3
    219 = 4
    212 = 5
    216 = 6
    214 = 7
    218 = 8
    085 = 9
    164 = PauseLive
    154 = Record
    234 = Event List
    102 = Info
    103 = Guide
    104 = Subtitles
    105 = List
    020 = Menu
    152 = Vol +
    021 = Vol -
    023 = Aux
    024 = Library
    027 = Return
    059 = Mute
    10/05/03
    169 = Clip
    084 = Yellow
    087 = Red
    088 = Blue
    100 = Unidentified {text?}
    106 = Play
    107 = Stop
    089 = 0 / Zero
    I'm missing most of the VCR functions (luckily Cursor L and R repeat the REW/FWD features), and the GREEN coloured button.
    I'd like seperate On, and Off codes but they may not exist.
    If anyone can add missing ones, or point us to a completed set...
    PS My remote is a OFA Topline 8
  2. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Also, I'm using the Pace DTVA code downloaded from http://www.oneforall-int.com. Device code number is 1323.
    Apart from the power button, I need to map the functions to each button myself.
  3. The Robman
    The Robman
    What's the device mode for the 1323 code (ie, VCR, CBL, SAT, etc) and what did you select at the OFA download site to get it?
  4. ingha
    ingha
    Jan 24, 2003
    7
    Lichfield
    I've just got a Pace Twin and have learnt most of the remote codes onto my Kameleon. There are three that it won't learn (pause, stop and exit) so I'm looking for some help. I've called the OFA helpline and they just said that a proper download is about 2-3 months away.
    I tried using the codes above but they didn't work unfortunately.
    Any ideas on what codes to use to programme the pause, stop and exit buttons ?
  5. The Robman
    The Robman
    Well, if Keven is correct that he was able to download the code he mentioned, you should be able to download that into the URC-8060 also and re-program the buttons using the advanced codes he posted. But I downloaded a bunch of Pace stuff and didn't get a 1323 code in the bunch, so hopefully he will post an update.
    Just FYI, all OFA remotes have limited learning memory, though the URC-8060 does have twice the normal amount. So, is it possible that you just ran out of memory, rather than there being something funny with those three buttons?
    If you have learned buttons for some of your other devices, maybe you should clear out the learning memory and re-program those buttons using advanced codes. Then start over learning the Twin and you will probably have enough memory to get all of the buttons this time.
    If you don't mind putting a bit of extra effort into programming the remote, you could check out the wonders of JP1. This would let you use the learning feature of the Kameleon to see what the IR signals look like, then you can use this info to build an upgrade for the Twin yourself and load it into the Kameleon, without waiting 2 to 3 months for OFA to catch up.
    Rob
  6. ingha
    ingha
    Jan 24, 2003
    7
    Lichfield
    Thanks for the response and you were exactly right -- I had run out of memory. Thanks also for the JP1 link -- I've had a look and will order one of the cables tonight.
    ian
  7. mortod
    mortod
    To answer the original question:
    091 Green
    228 Exit
    229 Fastforward
    233 Rewind
    231 Skip forward
    235 Skip back
    I've uploaded the full device config to the JP1 site at Yahoo.
  8. mortod
    mortod
    And to complete the set:
    232 TV2 CH+
    230 TV2 CH-
    And a bonus key:
    090 Slow motion
  9. The Robman
    The Robman
    Just FYI, the code for SLOW is the same as the LEFT ARROW button, which means you can play a show slowly by pressing the left arrow button.
  10. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    :laugh: Typical, there seemed to be little interest in this thread for days. I go away for two weeks, and it takes off!!
    iirc it was pace-6 that I downloaded.
    I still have the wav file from the download that included 1323. I guess it would be OK to e-mail it on to others?!
    :laugh: or I could play it to you other the phone....
    Also, thanks for supplying the missing codes. I hope to edit them into the full list one day.
  11. Spanjab
    Spanjab
    Apr 10, 2003
    33
    Is this a Pace Sky+ box?
