OEM or Retail DVD Writer???
Discussion in 'Desktop & Laptop Computers Forum' started by adrian3221, Apr 7, 2005.
  1. adrian3221
    adrian3221
    Dec 17, 2003
    717
    London
    +42
    I want to buy a DVD Re-Writer for my computer. I've noticed that you can buy two different versions of the same drive - OEM or Retail? From what I can gather the OEM version comes with no software, manuals, drivers etc and the retail version is fully boxed with everything but is more pricey. Have I got this right as I dont have much experience installing drives on my PC and would rather pay the extra and have the instructions to hand when it starts to go wrong!
    Thanks in Advance.
  2. shodan
    shodan
    Dec 11, 2001
    9,998
    shoeburyness
    +4,218
    I reckon that is about right! For ease of use and to save possibly hours of grief, I'd go with the retail version. I bought a Philips DVDR1640P. I'd never even looked at a writer before and I was able to instal, set up and start burning (with the supplied Nero software) in under 30 mins! Fantastic bit of kit!
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I wouldn't disagree with shodan's advice, especially for someone new to this technology, all I'd add is that there are no device drivers necessary for DVD players or burners.
    The PC's BIOS and Windows know all about them so all you need to do is install the device and connect the cables, on re-booting the BIOS will recognise it and Windows will install it.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    If you already have a DVD-ROM or even CD-ROM/RW drive and will replace it with the DVD rewriter then all you need to do is unplug the old drive and replace with the new useing the same cables. Other than making sure the jumper is set the same as the old drive that is all there is to it.
    But as has already been stated, if in doubt go for the retail version.
    Mark.
  5. nsherin
    nsherin
    May 14, 2003
    620
    Portsmouth, UK
    +23
    Agree with Shodan - I have the above drive in my home PC and it works a treat. There is also a multi-region firmware available on the web which works fine.
  6. Stone Free
    Stone Free
    Jun 13, 2001
    868
    28
    London
    +28
    OEM Drives do sometimes have software and manuals and cables, when I bought my CD ReWriter it came with everything, but when I bought my DVD Drive it just came with cables.
