chaz
Hoping I can get someone to help with a small problem please. I am jus putting my computer on its desk but now find that the cable from my "Harman Korden " Sound stick speakers is a bit short to go into the light green input on my computer is it possible to buy a extension cable so that it can reach the computer. I think it is a 3.5mm jack and it goes into female green socket on the rear of the computer (Should I buy a headphone extension)cable. Also if you do not mind me asking I think I will needing a longer DVI -DVI cable is it possible to get longer than the one supplied? And the last Q I need a wall mount for the monitor that makes the monitor be against the wall as the i use at the moment it sits out to far . See photo below also how high should the moniter be from the desk height I think mine is a bit to low Thanks
