Oddly enough Projector help, from you pro's
kevowen
I just made my first screw up buying a 4k projector, which was recommended by our AV guy.
I have a cinema room issue (unfortunately its not my cinema).
Firstly which one to buy.
Its a home cinema.
If i add the dimensions would someone be able to help and suggest what is best to buy?
Distance from Projector front to screen is 5m22cm
Screen
L 2.41m
H 1.36m
Diagonal 2.76m
The project fit in a ceiling box on the normal feet (it just slides in.)
AV Feed is via cat to HDMI convertor, to support Apple TV, Sky and Blue ray.
It has a RJ45 (i think it called that) to to do automatic power on and off, which ran from Ipads)
Too much info or?
I bought the view sonic x100 4k but its spread at 5m was about a meter either side of my screen.
Anyone able to help someone sort out their first pheck up in the projector world...
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
