Odd thing when changing country LG TV
Discussion in 'LG TVs Forum' started by Whiskeyjack1972, May 10, 2018.
  1. Whiskeyjack1972
    Whiskeyjack1972
    May 10, 2018
    3
    4
    UK
    I have the 49SJ800V and used EZ menu to change the country to US so I could add the Vudu app. But when i do this the magic remote stops working and the voice over accessibility feature is enabled.
    Does anyone know how I can remove this feature? At the moment I have to change country back to Europe but then Vudu removes itself the next time I restart the TV.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,375
    Lanarkshire
    +2,516
    Some features are only applicable to certain countries and as you've discovered weird things can happen when you prod around and change settings in the service menu...it's hidden for a reason.
  3. Whiskeyjack1972
    Whiskeyjack1972
    May 10, 2018
    3
    4
    UK
    Thanks for that really helpful comment.
