Odd Sky+ problem.
Discussion in 'Sky Digital TV Forum' started by martin99, Oct 25, 2004.
  1. martin99
    martin99
    Sep 23, 2004
    274
    Surrey
    +14
    Whats happening is that on any channel except 998 and 999 the box works fine for about 10sec, then the picture momentary freezes, then catches up. This repeats its self a couple of times,then the box resets itself. I’ve called sky and they will replace the box on Wednesday but I'm curious as to why 998 and 999 are not similarly affected?
    PS tried all the usual cures, master reset, forced download etc.. With no effect.
  2. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    This is probably because these channels are not recorded on to the hard disk with live pause etc. Try removing live pause, that might at least let you watch Sky until Wednesday though you probably won't be able to record.
  3. martin99
    martin99
    Sep 23, 2004
    274
    Surrey
    +14
    how do you remove live pause?
    cheers
    martin
  4. martin99
    martin99
    Sep 23, 2004
    274
    Surrey
    +14
    Ok, worked out how to turn off live pause and that has fixed it. So I figure the disk is duff. Anyway the box is still under warrantee so I'll wait till wednesday.
