Question Odd problem with Humax FOXSAT
Discussion in 'Freeview & YouView' started by PHOBIC ®, Feb 24, 2018.
Tags:
  1. PHOBIC ®
    PHOBIC ®
    Oct 19, 2004
    198
    UK
    I run both a Humax Freeview and Humax Foxsat boxes, and have them HDMI'd to my Samsung TV, and audio from TV to my Altec Lansing sub and sats
    I have the TV audio disabled, so that i control volume from either box via their own remotes
    Recordings audio and live TV audio from the Freeview box is fine
    However, the Foxsat box remote volume only works on recordings. Once i watch live TV, the Foxsat remote volume doesn't work, and i need to physically go to the Altec volume knob and adjust from there. Slightly inconvenient
    I'm wondering if have something set wrong somewhere - any ideas people ?
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,385
    Redditch
    +4,150
    In the Foxsat TV settings set up menu change digital audio out to stereo.
  3. PHOBIC ®
    PHOBIC ®
    Oct 19, 2004
    198
    UK
    There's only Stereo or Mono options. No Digital audio option
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,385
    Redditch
    +4,150
    MENU - SETTINGS - TV Setup - Dolby Digital - Off.
  5. PHOBIC ®
    PHOBIC ®
    Oct 19, 2004
    198
    UK
    Ah, yes i see whay you mean, but i was only concentrating on the audio option which only gives stereo or mono. The Digital option , which is under the audio option, has alway been off, so is not the cause of the problem.
    One thing Graham, i started to play the recording i had and volume on the remote works as i said, then immediately stopped the recording, went back to live TV , and the remote volume started working.
    As the audio out was already on stereo, and Digital was off, i never changed anything, so why it should start working on its own on live TV is a mystery. Seems more like a glitch
  6. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,385
    Redditch
    +4,150
    Try this, tune to a HD channel does the box volume work OK and then a SD one does it have the same volume ? It might be a hdmi handshake issue. Try a toslink connection to your amplifier from the Foxsat. Does the amplifier have a Dolby Digital decoder ?
  7. PHOBIC ®
    PHOBIC ®
    Oct 19, 2004
    198
    UK
    Just did that, and no vol difference between HD and SD, and remote vol still working ok on live TV.
    My amp system is an old sub n sats from Altec Lansing, and only has 3.5mm stereo inputs.
    What i've done to get audio from TV to amp is use an optical / toslink cable from TV to an optical/toslink box that converts into phono, then stereo phono to stereo mini jack to input on the sub.
    Works fine, if a little convoluted
  8. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,385
    Redditch
    +4,150
    You can get stereo audio direct from the Foxsat scart socket.
    https://www.amazon.co.uk/SCART-Adap...&qid=1519577229&sr=8-9&keywords=scart+adapter
  9. PHOBIC ®
    PHOBIC ®
    Oct 19, 2004
    198
    UK
    I presume i'd use that gadget alongside the HDMI out, but then would i have audio coming from both gadget and HDMI to the TV ?
  10. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,385
    Redditch
    +4,150
    It's not a gadget it just a adaptor that brings out the connections on any fully wired scart connection to allow you to use rca and composite video (and s-video if available).
    Leads Direct | SCART Wiring
