Odd problem with a 9/9p combi
Discussion in 'Arcam Owners' Forum' started by overkill, Jun 30, 2004.
Tags:
  1. overkill
    overkill
    Nov 6, 2003
    11,792
    Murkeyside
    +1,201
    Before the amps go to a dealer, can anybody make some suggestions on an odd problem with the units. This is, when playing music at low volumes there is a distinct difference in output betwen the left and right channel, with the right being louder. The higher the volume the less obvious it becomes - although a DB meter might say otherwise!. Bi-amping has had no effect.
    Although the overall sound has drastically improved!! :thumbsup:
    The only difference between the speakers, is one has banana plugs with soldered in cable, the other speaker, the left, has bare wire screwed in (until the 4 extra banana plugs arrive!). I can't realisticaly see this causing a volume level problem?
    I have tried swoping over channels on the CD (as it has a high output and is easy to tell) to check if it was a source problem, with no change. Ie the right channel was still louder.
    Odd huh!!????
    Time to see the Arcam repair man?
  2. Wingnut
    Wingnut
    I have an Alpha 9/9P combo, and don't experience this problem to the same extent you do, but when I turn the volume up very slowly the left channel kicks in before the right, but then at even low listening levels it appears to work fine. I suspect it will be a mis-match in the left and right volume control, something you may be experiencing to a greater degree.
    If it bothers you get it checked, you'll never be able to get it out of your head if you don't! I know I wouldn't :)
  3. booktrunk
    booktrunk
    Feb 6, 2004
    602
    Leicestershire
    +3
    Can you bypass the power amp section within the intergrated and just use the power amp and the 9 int as a pre. Just as a test.
    This way you can see if it's the pre amp section on the 9 causing it.
    Also... have you actually swapped the speakers over. I know you swapped the input from the CD Player over L to R etc... but it could be the speaker/cable so move this over to the R connectors and see if that makes a difference.
    Might as well ensure you have eliminated everything you can before sending it off.
    Steff
  4. overkill
    overkill
    Nov 6, 2003
    11,792
    Murkeyside
    +1,201
    Thanks guys!
    Yup. I'm going to try the integrated only next to see if that isolates it. I e-mailed Arcam and they felt it might be dodgy volume pot.
  5. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,137
    2
    +3,588
    I would suggest the same as they can get a bit tired over time and lose sensitivity at the bottom end- my (very) old Alpha 7 does much the same thing but it only powers my PC speakers so I can't get too excited.
  6. overkill
    overkill
    Nov 6, 2003
    11,792
    Murkeyside
    +1,201
    Next question is, are they easy to fit? My local dealer wants £50 before even we even start to look at the thing!! That's before parts, etc!! We will probably be talking the £90-100 by the finish. Not impressed. :mad:
