Odd motion artefact for NTSC playback...
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Peter Parker, Nov 21, 2003.
  1. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,231
    UK.
    +2,767
    I captured an NTSC laserdisk as high res NTSC AVI via a Belkin USB2(56gig for 40mins approx), and converted to NTSC DVD format. After editing out the gaps etc, and adding menus, I output the files to a VIDEO_TS file and burnt it to DVD +RW.
    Now, when playing back on a tv as PAL, the motion is smooth (other than what looks like 3.2 pulldown on pans), but there are jaggies which look like a scaling artefact. If I play it back as NTSC, the scaling is fine, but the motion has an odd judder to it.
    If I playback on the PC forcing weave, there is combing. The judder looks very much like the combing is being 'filled in' when being played on the tv. If I force Bob, the combing is gone, but the motion isn't as smooth.
    Any ideas as to how I can get a better result, i.e playback as NTSC (scaled correctly) but with smooth motion? I've a strange feeling it's a mismatch of video and film modes, but not sure where the error is occuring..
    TIA
    Gary.
  2. Koing
    Koing
    Nov 21, 2003
    189
    16
    What frame rate did you capture it in?
    And why the hell is the file so big?!
    Koing
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,231
    UK.
    +2,767
    Hi Koing,
    the capture/field rate was NTSC at 29.97 IIRC. It was an NTSC laserdisc, so I captured in the same format using an NTSC template. Maybe I should try inverse telecine perhaps?
    The file is large because it captures as uncompressed AVI (not DV AVI). Capturing to mpg2 produces poor results, but AVI to mpg2 is much better.
    Any ideas? I was also wondering if changing field preference form bottom to top would make a difference too.
    Gary.
