odd 'message' on Panasonic EH60D display
Discussion in 'Blu-ray & DVD Players & Recorders' started by stupidboyjj, Mar 17, 2006.
  1. stupidboyjj
    stupidboyjj
    Nov 16, 2004
    Can anyone tell me what this means - earlier today I turned on the EH60D to set the timer for a couple of programmes tonight. I have 'quick start' switched off so it takes a bit longer but I've never seen 'U80' or 'UBO' or whatever it said appear on the display.
    Normally when it's on and warmed up it displays the channel it's on and the time remaining to record on, but it was switching between that and this 'U80' message.
    Any ideas? Or did I misread it and it's something obvious?
    Ok - found a digitalspy posting where someone else has had 'U80' - is this something to do with the DVD part of the machine? If it's trying to write to my disc then no wonder there's an error - the disc in the machine is a 'proper' film. Does anyone know where to find a manual with the error codes in? The UK manual is useless, as we all know.
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,153
    +7,095
  3. stupidboyjj
    stupidboyjj
    Nov 16, 2004
    Yes, that was the thread - code didn't appear this afternoon when I turned it on. Might have just been a bit of dust or something then. Thanks for the reply anyway!
