Odd flicker/scanning
Discussion in 'Projectors, Screens & Video Processors' started by meep, Apr 20, 2003.
Thread Status:
Not open for further replies.
  1. meep
    meep
    Apr 22, 2002
    753
    46
    Ireland
    +103
    Hi All
    Had my Sony 1271 running for quite a while now and have recently noticed something odd.
    I can now see very fine flickering/scanlines on the screen, particularly when display white (such as all white warm-up screen).
    These are not the actual horizantal scanlines (which are also partially visible) but are much finer and seem to be some form of additioinal scanning running at about 5 degrees off horizontal.
    Now, the thing is, I'm not sure if they have always been there or not or have crept up gradually on me.
    I have determined that these are not input related as they are present during even warmup when I select an input with nothiung attached.
    Anyone any ideas whay this could be?
    (sorry I can't describe the issue better)
    Peter
  2. dprior
    dprior
    Dec 11, 2002
    14
    I also have a Sony 1271 and have what could be the same issue.
    I too had visible fine lines running almost horizontal usually only noticable when a large proportion of the screen is white.
    I adjusted the refresh rates in powerstrip until they dissappeared. This was a tricky process because when adjusting the powerstrip settings the 'MS Windows' windows are grey and fill a large area of the screen so I could only adjust and close all the boxes to get a white screen and see if the lines had gone.
    After a few attempts I did managed to get rid of the lines.
    However, I still don't know what the cause is. So, like meep I would be grateful for any clues.
    DP
  3. meep
    meep
    Apr 22, 2002
    753
    46
    Ireland
    +103
    Hmm,
    I don't fancy adjusting my refresh rates as I've just got things set up sweet for 50Hz Pal.
    Could bump to 75Hz but I'm happy with 50 as it doesn't tax the PJ much etc.
    Is it odd that these fine lines appear even on inputs with nothing attached?
    Peter
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Sounds like the fly back lines.
    G2's may be set too high.
  5. meep
    meep
    Apr 22, 2002
    753
    46
    Ireland
    +103
    Hmm,
    Haven't touched those in ages - do they slip?
    I've a feeling this means a full setup from scratch:(
    Regards
    Peter
Thread Status:
