Odd cabling query
Discussion in 'Cables & Switches' started by andyp2, Dec 12, 2004.
  1. andyp2
    andyp2
    I have been reading the Plasma forum for ages and decided to plump for the Panasonic 42" (new 7 series one). I have set it all up and everything works a treat, bar one thing which is confusing me big time. I can't seem to get sound out of my vcd/svcd's and some home made movies don't play the sound.
    Here is my setup
    42" Panny Plasma with Scart input x 1
    Sky+ Box plugged directly into the Plasma
    Toshiba 330 DVD Player, going into the Sky+ box via scart
    Yamaha VS-1 DTS Kit, Sky+ and Tosh plug into this via optical cables.
    It is really weird, VCD's especially have no sound, I have fiddled with the settings on the DVD player and fiddled on the receiver but I can't get sound. Does 2 channel audio not work through optical cable, does only 5.1 and DTS come through on that??
    Any ideas?
    My apologies if this is in the wrong forum.
