Quantcast
Oculus Quest Kodi
Yellowpinky
Hi all I've had the quest for a few weeks now and am really pleased with everything so far.
I'm aware that its android based and also sidequest..
I'm struggling to find any info on sideloading kodi apart from someone saying you can sideload it from sidequest and it works really well......
Problem is sidequest doesnt have kodi...Any help would be great...
aoaaron
Idk I just use skybox vr.. works well enough. I think the whole meta data thing is really overrated if it’s just a device for yourself
Yellowpinky
Thanks for the reply..I dont have any films tv shows etc on a local network ie pc....I wanted kodi to install a build and stream content from the internet..Also I use an iptv service also and would like to use that..
