Oculus quest 2 linkcable?
Bestchops
Hi there!
New and quite noob with the oculus quest 2.
However. My son wish to try out the link option. He has a PC with pretty god specs, but before buying the bit expensive oculus link cable, I went on and tried with just a “regular” USB C - USB 3 cable.
It should be able to transfer up to 5 gbit/s but it’s a 15$ cable.
It works, but a lot of lacking, especially in the menus.
Is this because of the cheap cable, and will the genuine oculus cable be that much better?
Sounds obvious I know, but curious on people’s experience with this.. thank you :)
KingD
Hard to say,
is it USB 3 on both sides?
Is it in a usb 3 port?
Did you do the usb test on the Oculus software?
What's his system specs?
Scootpb
The Quest 2 won't like it when plugged into a normal USB2.0. However it'll prompt you if you've plugged it in that way.
Make sure it's USB 3, and use a quality cable.
I've been using this with my Quest 2 with great success. No issues so far.
Amazon product
LG C1 OLED TV Best Picture Settings for SDR, HDR and Dolby Vision
