OCTO 8-output LNB
Discussion in 'Satellite TV, Sky TV & FreeSat' started by lonestar, Oct 27, 2004.
  1. lonestar
    lonestar
    Jul 26, 2001
    182
    maghera, n.ireland
    +4
    does anyone on here know if this will be compatible with sky digital?
    thanks.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    The best bet is to ask in the sites own forum, Martin who is Satcure will probably answer himself.
    My guess is that it is a universal LNB and as such will work with SKY hardware but it'll probably not fit a standard SKY minidish.
  3. cinesom
    cinesom
    Aug 30, 2004
    30
    Yes it will if it will fit on you mini dish - good gain actually!
