JustMefornow
Established Member
I've been using an Octava UHD41-ARC since January last year to be the link from all our various sources (Xbox One, PS4, Switch, Sky) and the TV. One simple cable routed in wall to the TV. U until mid-February it was working ok in our set up. BUT a couple of weeks ago we had an overnight power cut for a couple of hours. Since then, the unit keeps cutting audio out. Often you'll turn on TV, the source and the Switch. The picture will appear right away and there will either be audio or not (the source doesn't seem to matter).
At that point the only way you can get audio back is to switch the Octava unit off and on again (just by the power switch on the remote). Frustrstingly we could be watching Sky and change channels and the audio will cut out. You need to cycle the power again to get it back. This even happens when you start playing a prerecorded show from the Sky box. Off then on again.
I've tried changing source audio on the Octava remote and it makes no difference.
Any tips as to what would cause this and how to fix it before I go insane!
