Octava or HDanywhere
Discussion in 'Cables & Switches' started by alag20, Jan 9, 2012.
  1. alag20
    alag20
    Aug 20, 2008
    52
    Hi Guys,
    I am looking for a hdmi Matrix and wondering if people can give a reference or guidance.
    I was looking and have narrowed to Octava and HDanywhere 4x4 Matrix.
    I plan to hook a HDMI to ethernet adapter for one of the output - others will be on HDMI.
    Can someone guide which one would be better build and picture quality?
    I know HDanywhere is about £100 less than Octava. HDanywhere also offers IR return so that we can control the 4 input devices easily. Any more information?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,206
    The Borders
    +3,385
    There is no Video or Audio signal loss through the Octava unit.
    You can cascade one or more HDMI over Twisted Pair (CAT6 or CAT5) Extenders to the Output side of the Octava Matrix - recent updates to the Octava HDCATIR include PoC for single PSU installation.
    http://www.tmfsolutions.co.uk/Octava_HDCATIR-UK.htm
    Keep in mind most Extenders are not 'Ethernet' compatible - they just happen to use the same cable type.
    The Octava unit includes comprehensive EDID management and can be updated for EDID and Firmware via USB AND EEPROM.
    http://www.tmfsolutions.co.uk/Octava_HDMX44.htm
    Joe
  3. Member 213491
    Member 213491
    Aug 30, 2007
    860
    43
    Oxford
    +101
    I agree with JOE, EDID is a must.
    HDMI does play up and you need to put in some static EDID settings to get things running. With HDMI Matrix you need proper Tech Support.
    :clap:
