Hi All,
I have just received the keys to a new house and am in the process of wiring it with CAT6 cables for HDMI over CAT.
I want to be able to use the Octava 4X4 matrix for 4 displays, including a projector mounted on the ceiling. In addition, I want to be able to use the AV amp in the same room as the projector to do the sound decoding and to drive the speakers.
My problem centres on the ability to use one output from an Octava 4X4 matrix to provide video to the projector and sound to the AV amp at the same time. Is this possible? Are there any workarounds? Or is my only option to use the toslink out from the converter at the projector end and wiring it back downstairs to the AV amp?
In addition, does anyone know when the 4X8 switches may be available and how much they will cost?
Edit: Just noticed that UKHDMI.com have Octava switches listed on their website and state "optical audio output for integration with surround sound system". They state this for all the switches, whether over CAT or just plain HDMI, however per the images there are only HDMI outputs on the box. Can anyone shed any light on this?
Edit 2: 4X2 plain HDMI switch has toslink on output B, but none of the other switches which claim to have toslink appear to have it per the images. Does anyone have the 4X4 CAT switch and can confirm whther it has toslink out on at least one output?
