Octava 4x2 + 7.1 analogue and audio outputs
Nabs
I have a strange problem. I had my ps3 connected to my octave 4x2 hdmi 7.1 and output the audio to my amp via optical out until recently. I recently finally purchased some analogue cables. I have connected these and I appear to be able to output pcm ok through the analogues but when I use the optical out I appear to loose the centre channel, can the switch only either output via the analogue or optical or is there a fault somewhere else in the system?
Nabs
Yes, but why would that remove the middle channel when using optical out from the switch? It woks fine via the analogue outputs
Panasonic HZ2000 4K OLED TV Review | The best OLED for movie viewing in 2020
