Oc Season 2 £24.99
smashed
Sainsburysentertainyou run a promotion which allows you £5 off if you spend over £15. (you need to input a voucher code which I believe I cannot post here). If mods say I can, then I will.
The link below is to The OC Season 2. Currently £29.99 (as cheap as I have seen it)
Use the discount code, and its yours for under £25 :D
http://www.sainsburysentertainyou.c...ain.cfm?productid=D071103&pty=12320&sti=23729
(Hope that I havent broken any rules)
There are also a few other decent items for sale if you browse.
Even better, they dispatched my order within 4hours :)
Battle
They have series 3 of CSI for £14.99 for each half of the series - thats the cheapest ive seen it so far
and series 4 CSI boxset 2 for £19.99 - strangly box 1 is still £34.99 :confused:
smashed
PM me if you cannot find the code anywhere. But it WAS a general release code, so I should be allowed to post it on here?
Greg Hook
Moderator & Reviewer
If it is a discount code for general release then you can post it. It's the affinity type codes and non general public codes you aren't allowed to post.
smashed
Wahoo.. came back from work today.. and it had arrived already. Only ordered yesterday. That IS a record...
code is .. SB2874AA
thanks greg
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
