OB1i or FB1I with 2 X 909
iT Lad
Hi there, Newbie here.
I wonder if you guys could help me, I have heard this is the place to go to get some good straight advice...
I have...
99 CDP-2
99 pre Amp
2 X 909 Stereo 140WRMS (8ohms), 250WRMS (4ohms)
I can't change my amps as they sitting (Hidden) in custom made oak kitchen cabinet, but have a chance of some new speakers...
I have auditioned the PMC and like them allot... but will my amps be up to driving the OB1i's or should I stick with buying FB1i... hearts wanting OB1I.
I will now need a 13 Meter run for speaker cables, any issues or recommendations here..?
Also does anyone recommend a FM/DAB tuner to hook up to my system for around £300
Thanks in advance if you guys can help, much appreciated. :smashin:
alpha10
I think the general advice these days is get the best speakers you can afford. So if you can OB1i's :smashin: I am very pleased with mine
In my experience if you are questioning it now, buying the FB1i's would be a mistake as you would (well I would) always be thinking "if only.."
alpha10
Thanks alpha,
Do you know if the 2 X 909's will be powerful enough to drive the OB1i...
:smashin:
Easily I would have thought they are not difficult to drive. You could always pick up another 909 and tri-amp :devil:
There is a PMC owners thread on here if you search, might be worth a read through, I have a vague recollection that there was someone using 909s
Member 410254
Established Member
Have you tried the FACT 8? The OB1's will be sound fine with the 2 x 909's, the OB1's will take MORE current than that though! Have fed them with MF Superchargers and the OB1's didnt blink!
Regards
Phil @ Custom Cable
🎬 Across the Spider-Verse, Fast X, Covenant, Sisu, Changeling 4K, Lighthouse 4K, Quantumania 4K & TV
Back
