Question Oak TV Unit
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Flippoc, Dec 2, 2017.
  1. Flippoc
    Flippoc
    Dec 2, 2017
    62
    2
    Bucks
    +65
    Hi all,
    I am new to these forums and have just purchased a LG 55c7 Oled tv. I will be adding to it a Denon avr2400 and 5.1.2 setup.
    The question I have is, I need a nice piece of oak furniture to place everything on.
    The Tv will be wall mounted so the top of the unit will only have centre speaker on and I would like 2 shelves with one being tall enough to place the Denon on which is 170mm tall approx.
    Also an Xbox, Bluray player etc will need to go on it.
    Any suggestions as can't find anything with deep enough shelf.
    Many thanks,
    Phil
  2. Mr Andy
    Mr Andy
    Jul 16, 2009
    546
    28
    Nottingham
    +26
    That's not as deep as some so you've got some choices, though some may want the back off with cables sticking out the back. How big is the centre speaker? Would you be ok with something where you can have two shelves on one side and one on the other for the amp? If you have a 200mm spacing plus another shelf, with the centre speaker above that your TV may be very high.
    I looked at these
    Techlink PM160LO TV Stands
