Oak Pine Shop - Another Happy Customer
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Eddy555, Feb 14, 2017.
Tags:
  1. Eddy555
    Eddy555
    May 19, 2007
    4,727
    2
    +2,914
    Just had my cabinet delivered from The Really Good Oak Shop (a.k.a. Oak Pine Shop) after seeing some recommendations on this forum.
    I'm delighted with it, it's just as I wanted and really solidly built.
    They were a pleasure to deal with, well priced and delivered on time as discussed.
    I'd struggled for a long time to find a cabinet that would fit my AV equipment and a tower PC (Gaming/VR etc.) and just couldn't find anything, so I custom designed it, and they built it to my specs.
    I believe they also have a standard range of units as well.
  2. steel_kelly
    steel_kelly
    Apr 7, 2005
    150
    middleton, manchester
    +21
    Any pictures of the av equipment fitted?
  3. Eddy555
    Eddy555
    May 19, 2007
    4,727
    2
    +2,914
    Will post some up later on, it may look a bit tight for airflow, especially in the amp, but it's all running fine for me
  4. Eddy555
    Eddy555
    May 19, 2007
    4,727
    2
    +2,914
    I'll try and remember to post a pic tonight :)
  5. Eddy555
    Eddy555
    May 19, 2007
    4,727
    2
    +2,914
  6. Eddy555
    Eddy555
    May 19, 2007
    4,727
    2
    +2,914
    If there's one thing I'd change on my design (and it is my fault for not thinking about it a bit more) I'd give the amp slot another 25mm height to give a bit more room for airflow. The current height hasn't caused me a problem, and the amp fan has only come on once at a low level after a particulaly hard work out from Mad Max Fury Road. Other than than, I'm really happy with it.
    The quality of the build really is top notch.
  7. Syphon
    Syphon
    May 26, 2005
    509
    2
    +11
    Hi Eddy,
    That looks great and just what I'm after. If you don't mind would you be able to share the measurements you used to provide to them and a rough idea of cost?
    Many thanks,
    Scott
  8. Eddy555
    Eddy555
    May 19, 2007
    4,727
    2
    +2,914
    Hi thanks, I'm very pleased with it.
    Attached is the PDF I sent them
    I can send you the Sketchup file I used for this as well if you'd like to mess about with the design. It's too big to attach here
    :smashin:
  9. Syphon
    Syphon
    May 26, 2005
    509
    2
    +11
    Very kind thank you.
    I'll PM you my email if you don't mind sending the file.
    Ta :)
