Quantcast
O2 Joggler in wall install with Squeezeplay/box & Squeeze server
c13ugg
Hello,
Exclaimer.... Try this at your own risk. I have this running on 3 joggler devices.
Thought i'd add a thread for anyone wanting to play their music library remotely at a reasonable cost.
I have
O2 Joggler - with stock os
Amp - Sony 5400es
3.5mm jack to RCA
PC Running Logitech Squeeze Server 7.7
Kitchen Ceiling B&W CCM80's x2
iPhone remote control
In my case, I wanted to have a device capable of playing my iTunes library sunk into the wall. The O2 jogglers we're going cheap £50 so I decided I'd try one of those. As standard its more a desktop calendar and picture frame. The chrome stand is used as a heat skink, however in my case i have some space behind the unit and it doesn't get hot during use.
So to start, i hack sawed off the stand on the O2 Joggler. I placed it face forward and thinly drew around the face to create a template for cutting the plaster board. I cut inside the line as the joggler has an angled edge which allows it to wedge its self in the wall.
You'll see that in this case I have it connected to an ethernet cable. That was because I significantly changed the kitchen and planned for a cable in preparation. That said, it works completely fine using the built in wireless as demonstrated on my other jogglers. I also have a 3.5mm jack that links to the zone 2 of my sony amp to power 2 B&W ceiling speakers. This isn't necessary as the joggler has its own built in speakers.
Next, the server software. Its available from here. It works on linux, windows, netgear ready naz, mac etc etc etc...
In my case, I wanted to play my music in my iTunes library. I'm fortunate in the fact that I selected the option for iTunes to manage my library, so all my music is stored in one folder under iTunes. You can set the software to search on you HDD in any or every folder. It uses the meta data to display album art and artist info etc which is nice. It also provide access for nearly every radio station on the planet with 4000 stations.
In my case, the server software also uses DLNA so i can stream video content to my iphones and playstation 3.
Next step, you need to install the squeezebox SW on the Joggler. Do this at your own risk.
Step one, you need to enable SSH / telnet on you joggler. You do this by following these steps Enable joggler SSH.
Step two, install squeezebox SW on joggler here
One cool feature, you can remote control from the iPhone.
I have downloaded the app which allows you to control the entire experience remotely!
I've attached some pics of my install.....
inzaman
This looks well cool, so you have a server with all your music on it and the joggler can link to that via wireless?
c13ugg
Hi Inzaman,
Thats right, I use a desktop PC with win 7 to host all my media. The software support radio, video, picture and music streaming.
It streams music no problem over wireless. Video work also, but if the bitrate is too high it will stutter due the the wireless bandwidth. I convert videos to between 300 - 500mb and they work okay.
C13UGG
towns
Does it go to sleep if you don't use it for a bit or have a power button on screen?
c13ugg
Hi Towns,
there are a number of different options...
From the ones I've seen you can
  • Set to go to sleep and turn display off after certain amount of time
    Play pictures from facebook or similar
    Set a digital or analogue clock.
    when playing
    when stopped
    change delay
    these are just a few
On mine, I have it set to clock after 15 minutes or close and use the joggler clock.
I'm pretty sure it has a light sensor and changes the brightness accordingly
djmike
Hi C13ugg
Just had a look at the links you provided for getting the squeezeplayer software onto the joggler. i used the Easy way (new version) in the link you provided to enable SSH / telnet on the joggler did you use that one as well, only ask as when i plug my formatted usb stick with downloaded file unzipped to it, all that happens is it boots up and goes to the normal menu screen, am I suppossed to be seeing something else as I cant seem to enable the SSH and SCP files.
Any help greatly received
NickSee
Hi DJMike,
I'm in the process of jogglering my home, have bought 5 on fleebay, the first 2 have arrived so far and I'm running squeezebox server on a win7 pc with squeezeplay on each joggler with native OS.
I too have followed the 'easy way' to gain SSH access in order to download the birdslikewires.co.uk squeezeplay code - fantastic work by those guys and I will donate some beer funds to them next week when the other jogglers arrive - but with my second one I had the same symptom you describe and thought uhoh this one might have a problem reading from USB.. but actually it was the software version being incorrect. Because I'd already configured that joggler on the wireless network though, by the time I rebooted it, it had already updated to the June 2010 o/s version and took the SSH configuration from the USB stick no problem second time around.
So I'm hoping you hadn't got yours on the network with internet access at the point you had the symptom - go into settings > about and check the software version there....
HTH :rolleyes:
Nick
djmike
hi nicksee
Im running the latest version of the software June 2010, I think I've narrowed the problem down to the USB stick not being compatable as I get an error message on telnet saying it cant access port 23 apprantley reading on another forum you get this message when the USB stick is not compatable with the joggler, will pick up a scan disc USB stick today and see how I get on with it.
I take it I'm right in saying when you open up telnet you type 'o' for open then type the IP address of the joggler and then all should run fine from then
Mike
NickSee
DJMike
apologies to C13Ugg for thread hijack (in my defence I did discuss holes in our kitchen wall today with my other half for jogglerisation :smashin:)...
sounds like you are onto the snag then, on telnet I can't confirm the 'o' for open as I used a freeware program called PuTTY which I found out about whilst doing some home automation stuff, on that you just tick the SSH box and enter the joggler's ip address and up comes the window of the telnet session.
djmike
Nicksee
Ive now tried 3 different USB sticks and used the PuTTY software, I can mange to type the username but it seems to freeze after that so I cant type the password, any ideas would be great as Im getting a bit peed off with it now as it shouldnt be as hard as this
cheers
NickSee
DJMike
Forum won't let me reply to you Mike sorry - so I'm trying to edit my post instead... sorry you are having such a hard time, my first two behaved perfectly which will probably pee you off even more but at least you know it should be easy!
Just looking again at the birdslikewires instructions below.. what username are you trying? Note that the easy method for native os doesn't use the username instructed below..
First, log in to your Joggler using the Terminal app on Mac OS X or Ubuntu, or PuTTY on Windows. If you have followed the SSH instructions linked to above your username will be ‘letmeinssh’ and the password will be ‘joggler1234’ by default.
djmike
Hi Nick
Just wondered what link your using to download the ssh as I was using the one where the username and password are joggler
truxntrax
I also use the joggler but use squeezeslaves running on a sheevaplug.... Should be able to do the same with Raspberry pi's.
The audio quality on the joggler audio out is terrible - using the slave with a usb audio out solves this!
c13ugg
Hi DJmike,
I was doing this one a MAC to begin with and there were issues with the extraction. Not all the right files we're extracted, there were some with certain extensions that I think were hidden. The files I have are as follows.
I have a 3rd joggler that I haven't done so I'll try and write some more instructions.....
First, the joggler IP address.
Settings > Network > its at the bottom
in my case its 192.168.1.169
DL and extract the SSH - be careful, I needed to do this on windows as I dont think it copied all the files on my MAC. This is what it should look like on a MAC
This is what I extracted on my Win PC to an external pen drive
Turn joggler off at mains or unplug. Then connect your USB pen and switch back on. ( you will not notice any difference)
I've copied my installation experience below, I typed part that are italic and red. if you're using windows you should be able to use Putty.
C13ugg-MacBook-Pro:~ C13ugg$ ssh [email protected]
The authenticity of host '192.168.1.169 (192.168.1.169)' can't be established.
RSA key fingerprint is 8d:4d:f3:f5:00:f9:28:29:84:0c:50:cd:80:10:a9:b5.
Are you sure you want to continue connecting (yes/no)? y
Please type 'yes' or 'no': yes
Warning: Permanently added '192.168.1.169' (RSA) to the list of known hosts.
[email protected]'s password: joggler
# cd /media
# wget http://birdslikewires.co.uk/download/joggler/squeezeplay/sqp.sh
Connecting to birdslikewires.co.uk (64.90.54.137:80)
sqp.sh 100% |*******************************| 14885 00:00:00 ETA
# chmod +x ./sqp.sh
# ./sqp.sh installcd /media
SqueezePlay for Joggler (Native) v1.31 (7.7.1-9561)
This script installs or removes SqueezePlay for Joggler.
WARNING! It is entirely possible that this script could cause your
Joggler to stop working, as it modifies essential system
files. Every care has been taken to avoid this happening,
but you must only continue if you accept this risk.
No responsibility will be accepted for any damage and this
software is provided without warranty.
Press <ENTER> to installcd, or CTRL-C to exit.
"I pressed enter"
If you find SqueezePlay for Joggler useful, you might like to make
a contribution towards it's hosting. If you would like some info,
please visit birds like wires | Contributions
Thanks!
# chmod +x ./sqp.sh
# ./sqp.sh install
Press <ENTER> to install, or CTRL-C to exit.
Thanks!
Installing the Little App Launcher v1.08...
launcher108.tgz 100% |*******************************| 43106 00:00:00 ETA
Checking that server will launch on boot... done.
Installation of Little App Launcher is complete.
Installing SqueezePlay...
Fetching SqueezePlay v1.31 (7.7.1-9561)...
squeezeplay-thinned- 100% |*******************************| 6208k 00:00:00 ETA
Fetching SqueezePlay for Joggler components v1.31...
squeezeplay-joggler- 64% |************************************************************************************ |squeezeplay-joggler- 100% |*******************************| 5999k 00:00:00 ETA
Fetching the launcher component...
squeezeplay-launcher 100% |*******************************| 5974 --:--:-- ETA
Decompressing... done.
Adding launcher... this takes a few moments... done. "Joggler rebooted"
SqueezePlay installation is complete.
c13ugg
The audio on mine seems to be okay. I have to connected via RCA to my amp? Maybe that improves the quality?
NickSee
Hi again Mike - forum still won't let me reply in the thread, most weird... anyway just to let you know I had one of the five jogglers that wouldn't let me SSH into it with uname Joggler pword Joggler but instead wanted uname 'letmeinssh' and pword 'joggler1234' I presume because its previous user had already installed the SSH mod. You are linking to the right place though.
Nickffc
just got a joggler from another AV member... great bit of kit...
managed to install squeezeplay now...first time i've ever tried that sort of thing...!
got a question.... my music on my mac is kept on an external drive but i cant quite work out how to point the squeezeplay to use this drive...it just seems to want to use the default itunes music folder....is there a way of changing this...?
Nick
Nickffc
BTW nice install in the wall.... might try and do the same but in the bathroom....!
djmike
C13Ugg
thanks for that did actually manged to sort it last week and totally forgot to get back to you, one question I cant seem to see all my song on itunes throught my squuezebox and or joggler seems to be not picking up all the albums etc any ideas
cheers
c13ugg
I have Itunes arrange my library, and so point to that directory.If your music is in different places you can add additional directories. In terms of other drives etc.... you can change in the control panel for squeezeserver
i've attached two pics showing where....
Nickffc
are those menus from a PC....?
the logitech media server running on my mac looks nothing like that...?
Trending threads
Latest News
Britbox now available on LG smart TVs
  • By Andy Bassett
  • Published
Virgin Media TV customers get 18 free channels
  • By Andy Bassett
  • Published
AVForums Podcast: 6th April 2020
  • By Phil Hinton
  • Published
BenQ launches new Home Cinema and Gaming projectors
  • By Andy Bassett
  • Published
Acorn TV streaming service to launch in UK
  • By Andy Bassett
  • Published
