O Brother, region 1 or 2?
Discussion in 'Movie Forum' started by marcoeser, Apr 18, 2001.
  1. marcoeser
    marcoeser
    Jul 17, 2000
    341
    hi everyone,
    I recieved a present of "O brother, where art thou", with region 2, but I already have it on back order with region 1. What should I do? Does anyone know if there are any difference in quality and extras? Should I return the region 2 and wait for region 1, or engoy the film now and not worry about the difference?
    Marc=)
  2. marcoeser
    marcoeser
    Jul 17, 2000
    341
    sorry people,
    I dove a little deeper and found that region 1 has DTS and the region 2 doesn't!
    I dont know why they've deleted that format? I'm going to wait for DTS! :)
  3. cozzer
    cozzer
    marc,
    the region 1 will also have featurettes on some of the special effects - apparently, a deconstruction of the flood scene at the end. i know - i've just bought the film on region 2 because i couldn't wait for the region 1. but again, we're getting bloody conned. check out 'dancer in the dark' as well - funded by film four and the region 1 disc gets dts, 2 audio commentaries, 2 featurettes, etc.
    sort it out! :mad:
  4. Guest
    My girlfriend just purchased the R2 disc of O Brother and we found it was only in Prologic when the back of the box says 5.1 DD. Have you found the same thing on your disc?
  5. Arthur.S
    Arthur.S
    I had the same prob on my Sony 735. Someone on this BB told me the answer; select 5.1 using the Audio button on the remote, NOT in the audio options on the disc.
    Great film by the way. ;)
