NXT flat panel speakers for rears
Discussion in 'Home Cinema Speakers' started by colinstone, May 3, 2003.
  1. colinstone
    colinstone
    Apr 10, 2003
    11
    Oxford, UK
    Anyone tried using NXT flat panel speakers as rear speakers in a 5.1 set up??
    Seems to be that it might have something to offer??
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    I tried using Wharfedale Loud Panels in my 5.1 set up but found the results poor. Because the speakers are non directional it sounded odd. The other problem with these particular flat panels is they are large and difficult to get at ear level behind you ( too low to hang pictures).
    Mylo
  3. nathan_silly
    nathan_silly
    If they are non-directional they could work well as sides (ie as in the THX spec- they recommend dipoles as sides)
  4. avanzato
    avanzato
    Jan 21, 2003
    1,963
    Norfolk
    +82
    I used loudpanels for about a year and they work pretty well. The sound fills the room so you get the surround effect from a large listening area.
    The main problem is that they are large and you need to find a place to fit the subwoofer module which is a bit of a boom box. I used them with a PS1000 sub instead for a while and it was a noticable improvement.
    If you want to experiment then try getting some ARC Sonare speakers, the last price I saw them for was £37 in Miller Bros for a whole 5.1 system. The sub isn't much good but the panels sound OK. My brother has them and is happy with the sound.
