NWHD5 Quick Question re: Sonic Stage & CD's
Paul MC007
Hi all
Just a quick question....
Sorry to be a bit thick on this, after connecting up my HD5 to the pc and by using Sonic Stage, can I transfer tracks back from the HD5 and then burn the atrac plus3 tracks to a normal CD for playing in any CD player???
Thanks for any help
Paul
drmoze
No. You can use the tracks on your pc and burn them to a normal cd format. You should NOT delete your ripped files from your pc! The HD5 is a player, NOT a backup/storage option! DRM means you can't copy files FROM the HD5 TO the pc.
Paul MC007
Thanks for your help on this ..
Paul
drmoze
It's a PITA, but yeah, this is how DRM works. OTOH, if you rip your own CDs using SS and uncheck the DRM option, you can simply copy the files to a backup drive and later import them into SS on any pc.
Panasonic HZ2000 4K OLED TV Review | The best OLED for movie viewing in 2020
