NWHD3 and playlists...Moodlogic?
Discussion in 'Headphones, Earphones & Portable Music' started by djbrightman, Feb 17, 2005.
  1. djbrightman
    djbrightman
    Feb 16, 2005
    15
    I'm looking to buy a hd player and, technically, it looks like the Sony NWHD3 is miles better than iPod - lighter, longer battery, better shock...?
    However, it sounds like SonicStage is rubbish...?
    I'm interested in being able to put together playlists, mark favourite songs, etc. - things it sounds like iPod/iTunes do very well...?
    After digging around it looks like Moodlgic do an organiser that might fit the bill. It looks like it works with SonicStage for some of the NetMD walkmans... Does anyone know if it will work with NWHD3?
    Any comments/suggestions welcome!
    David
  2. hughesy
    hughesy
    Jan 22, 2005
    848
    Irish in Oz
    +13
    Sonic stage is bad!!!
    Not sure about moodlogic, will try it tonight and get back to you tomorrow. I just know that i had a VAIO and the moodlogic software came with it, so that looks good.
    Also it looks like there is sony software that allows you to bypass sonicstage look here
  3. hughesy
    hughesy
    Jan 22, 2005
    848
    Irish in Oz
    +13
    Unforturenty i'm no use, you need to be connected to the web for moodlogic to worka and my pc at home doesn't... sorry :(
    When installing it gives u an option to download extra stuff to be able to access ipods and other mp3 players!!
  4. djbrightman
    djbrightman
    Feb 16, 2005
    15
    Thanks for trying, I appreciiate your efforts.
    Anyone else out there using MoodLogic?
    David
