nwhd1 neck strap
Discussion in 'Headphones, Earphones & Portable Music' started by jenniferd, Feb 10, 2005.
  1. jenniferd
    jenniferd
    :hiya:
    Is there a neck or wrist strap available for the sony nw hd1?
  2. dj001k4727
    dj001k4727
    Try looking at sony.com (based in the states) not co.uk...and look under carry cases they have lots of swag like this. The problem is trying to order it because as there is a nice little case for it that ive got my eye on and the on line order form only allows U S addresses. If you manage to order anything off tell me how you did it.
    Im using mine with a nokia neck strap the only problem with using it is the loop eye on the unit is located opposite to the headphone output which tends to tangle things up a bit when hanging from your neck......Remember any thing over eighteen POUNDS will be sudject to import duty............DJ
  3. jenniferd
    jenniferd
    someone is selling the carry case on ebay, its $30 tho but it doesnt come with a neck strap :(
  4. Kiai
    Kiai
    Jan 31, 2005
    3
  5. dj001k4727
    dj001k4727
    Nice one Kiai !
  6. ipodrob
    ipodrob
    On the subject of cases I just got a leather one for my NWHD1 from PDair shop http://www.pdairshop.co.uk/product_info.php?products_id=183
    It's a very nice piece of kit but obviously more expensive than the basic sony case. I saved a bit of money on the player itself so I splashed out on a luxury case. It's nicely padded, has a sturdy belt clip & a flap which covers the face.
    It came to 26.52 including delivery (I ordered at lunch time and it arrived the following morning). Very happy with it - and the service.
