NW-HD5 compatibility
Discussion in 'Headphones, Earphones & Portable Music' started by sammywammy23, Jul 4, 2005.
  1. sammywammy23
    sammywammy23
    Hello, I'm from Europe and I'm going to buy a Sony NW-HD5 or NW-HD3 in America. I have two questions:
    Will I have any problems with using it? Are the american versions very different to the european versions? if so what are they?
    Most importantly
    For the program, will the american version work on my computer. Is Sonic stage compatible with Windows 98 SE
    thank you in advance
    Michael
  2. gtv
    gtv
  3. clivem2
    clivem2
    Your main issue to to check the warranty, is it worldwide?
