NW-HD3S Problem
Discussion in 'Headphones, Earphones & Portable Music' started by moggy44, Aug 17, 2005.
  1. moggy44
    moggy44
    I have read the Problems that there seems to be with this MP3 Player but not sure if this falls in the same problem.
    When playing it seems to jump back and forward from the track you are playing and another track and back again, also sometimes it freezes.
    Would be grateful for any help. :lease:
    Regards John
  2. JB5
    JB5
    Apr 18, 2005
    231
    +16
    Somebody reported some success solving this problem by defragging their player.
    If you've added and removed lots of tracks from your player then this might help.
    The process is S L O W but shouldn't cause any problems, but in any case make a backup of your PC library before starting!
  3. RobbySpurs
    RobbySpurs
    Feb 23, 2004
    4,727
    London
    +2,867
    This might sound a little obvious, but do you have the machine in your pocket when this happens? Sure you are not just knocking the forward/ rewind buttons, or hitting the pause button. Easily done in a pocket unless you lock the keys!
